I Require a VBA to download information from URL.
Currently, I have to key-in 3 information to obtain required information.
I Require information for 24 years from 1997 to 2021. I am in need of a VBA where I have to key in just one information to get information for 24 years.
I used the following VBA but it shows error as Run time error 91 (object variable or with block variable not set).
Is it possible to modify the VBA I am using to retrieve information of the following 3 URLs?
Thanking in Advance.
Link 1
1998 Pratipada tithi dates. Krishna & Shukla paksha Pratipada in 1998, next Pratipada date with exact start and end time.
Link 2
Hindu calendar November 2007 with festivals & daily panchang. Holidays, daily tithi, vrat, Hindu festival calendar November 2007.
Link 3
Find your Nakshatra. This Nakshatra Calculator helps you find your Janma Nakshatras. There are 27 nakshatras and nakshatra is an important aspect of Indian astrology
Public Sub Comets3()
Dim cometCells As Range, cometCell As Range
Dim inputDate As String, startDate As Date
inputDate = InputBox("Enter start date")
If inputDate = "" Then Exit Sub
startDate = CDate(inputDate)
With ActiveSheet
Set cometCells = .Range("A2", .Cells(.Rows.Count, "A").End(xlUp))
For Each cometCell In cometCells
Application.StatusBar = cometCell.Value
Get_Latest_Details "https://in-the-sky.org/ephemeris.php?startday=" & Day(startDate) & "&startmonth=" & Month(startDate) & "&startyear=" & Year(startDate) & _
"&ird=1&irs=1&ima=1&iph=0&ias=0&iss=0&iob=1&interval=0&tz=0&format=csv&objtype=3&objpl=" & Escape(cometCell.Value) & "&objtxt=" & Escape(cometCell.Value), _
cometCell.Offset(0, 1)
DoEvents
Application.StatusBar = ""
MsgBox "Finished"
Private Sub Get_Latest_Details(URL As String, destinationCell As Range)
Static httpReq As Object
Dim HTMLdoc As Object
Dim table As Object, dataRow As Object
Dim i As Long
If httpReq Is Nothing Then Set httpReq = CreateObject("MSXML2.XMLHTTP")
With httpReq
.Open "GET", URL, False
.send
If .Status = 200 Then
Set HTMLdoc = CreateObject("HTMLfile")
HTMLdoc.Open
HTMLdoc.write .responseText
HTMLdoc.Close
Set table = HTMLdoc.getElementsByTagName("TABLE")(1)
Set dataRow = table.Rows(3)
For i = 0 To dataRow.Cells.Length - 1
destinationCell.Offset(0, i).Value = dataRow.Cells(i).innerText
Set HTMLdoc = Nothing
destinationCell.Offset(0, 0).Value = "Error"
destinationCell.Offset(0, 1).Value = URL
destinationCell.Offset(0, 2).Value = .statusText
Private Function Escape(ByVal param As String) As String
Dim i As Integer, BadChars As String
BadChars = "%<>=&!@#$^()+{[}]|\;:'"",/?"
For i = 1 To Len(BadChars)
param = Replace(param, Mid(BadChars, i, 1), "%" & Hex(Asc(Mid(BadChars, i, 1))))
param = Replace(param, " ", "+")
Escape = param
End Function
Link 1
Link 2
Link 3
