Not equal to in a function
Bryz
Hi all,
Just would like to know if there is a way to use an if function that refers to a not equal to (e.g. =if(a2"does not equal to"b3,....))
Thanks!
Bryz
Hi Bryz ,
Certainly ; your IF statement would be :
=IF(A2 <> B3 , .... , .... )
The combination of <> is used for the inequality ( not equal to ) comparison.
Hi Narayan,
It doesn't seem to work. I've uploaded part of the worksheet I'm working on. I'm trying to get column H reflect the current employer if they have changed (i.e. they have terminated from company a and moved to company b).
Bryz
Hi Bryz ,
The correct logic would be as follows :
1. Let us assume that the combination of the Given Names and the Surname will be unique ; this combination can be derived by using C2 & " " & B2.
2. Compare the combination in any row with the combination in the next row ; if this is not the same , then the employee has not been terminated , and is continuing in the same company.
3. If the combination is the same in two successive rows , and the employer is different , then there is a change of company.
If we put all of the above together , our formula would be :
=IF(C2 & " " & B2<> C3 & " " & B3,IF(C2 & " " & B2<> C1 & " " & B1,D2,""),IF(D2 <> D3, D3, ""))
Another possibility would be :
=IF(C2 & " " & B2<> C3 & " " & B3,D2,"")
