how to create formula for automatic subtraction
legolas
I'm trying to prepare vehicle mileage report based on vehicle number (column B) and date (A) , pls see attached
is it possible to have in E a formula to do the subtraction of last and first mileage in C based on same month in A ?
i just need to calculate how many kms a vehicle travelled each month
i hope it is clear enough and thanks for your help
This is a 365 solution.
= LET(
    startMonth, 1+EOMONTH(+date,-1),
    distinct,   UNIQUE(HSTACK(startMonth,vehicle)),
    start,      CHOOSECOLS(distinct, 1),
    end,        EOMONTH(start, 0),
    plate,      CHOOSECOLS(distinct, 2),
    max, MAXIFS(mileage, vehicle, plate, date, "<="&end),
    min, MINIFS(mileage, vehicle, plate, date, ">="&start),
    HSTACK(TEXT(start,"mmm"), plate, max-min, max)
81109
My code was a worksheet formula, not VBA. It is functionality that has been introduced to Excel over the past 4 years and is only available in Excel 365. HSTACK is only just coming out of beta-testing but the results could be returned column by column without it. I use defined names for all references, so 'date' and 'vehicle' are created using Name Manager. If the sheet I attached did not work, you most likely have a legacy version of Excel.
