help in vba
asafraz81
i have seen the lesson in utube called vba crash course.
i copyied the module as is to visual basic.
the problem is that i get an eror while trying to run the code.
i add the code to the post with the debug line with three Asterisks.
i wil be glad if u cuold help me solve this, i want to study this complex code and be able to build macro this level.
thanks
asaf raz (from israel)
Function checksales(inthisrange As Range) As Boolean
checksales = WorksheetFunction.CountA(inthisrange) > 0
End Function
Sub processales()
If checksales(Range("c7:c30")) = False Then
Debug.Print "no sales"
Exit Sub
Dim storesales As Range
Dim sumofsales As Double, cursale As Double
Dim countofsales As Integer
Dim minsale As Double, maxsale As Double
Dim reason As String, massage As String, minstore As String, maxstore As String
sumofsales = 0
countofsales = 0
minsale = 99999#
maxsale = 0
For Each storesales In Range("c7:c30")
If storesales.Value <> "" And storesales.Value <> 0 Then
***cursale = storesales.Value
sumofsales = sumofsales + cursale
countofsales = countofsales + 1
minstore = IIf(cursale < minsale, storesales.Offset(, -1).Value, minstore)
minsale = IIf(cursale < minsale, cursale, minsale)
maxstore = IIf(cursale > maxsale, storesales.Offset(, -1).Value, maxstore)
maxsale = IIf(cursale > maxsale, currentsale, maxsale)
If cursale < 500 Or currentsale > 5000 Then
reason = InputBox("reason for low", storesales.Offset(, -1).Value)
storesales.Offset(, -1).Value = reason
Next storesales
If countofsales > 0 Then
Message = "we operateda total of " & countofsales & "stores today" & vbCrLf
Message = Message & "we made a total of" & Format(sumofsales, "$#,#.00") & vbCrLf
Message = Message & "max sales we had is " & Format(maxsale, "$#,#.00") & "from" & maxstore & vbCrLf
Message = Message & "min sale we had is " & Format(minsale, "$#,#.00") & "from" & minstore & vbCrLf
MsgBox massage, vbInformation + vbOKOnly, "daily sale status- " & Format(Now, "dddd,mmmm,d,yyyy")
[valdailylogtitle] = "daily sales status- " & Format(Now, "dddd,mmmm,d,yyyy")
[valdailylogsummary] = Message
Range("areadailylog").ExportAsFixedFormat xlTypePDF, ThisWorkbook.Path & "/dailysaleslog-" & Format(Now, "ddmmyyyy-hhm") & ".pdf"
[valdailylogtitle] = ""
[valdailylogsummary] = ""
Asaf, I'm not certain exactly how this report is supposed to be structured, but I copied your code into a module and worked out all the kinks I could identify. Below is the revised code I came up with.
In a few cases, you had an undeclared variable (cursale was declared, but in some places it was currentsale; the same goes for message and massage). Also, I added indentation for the If-End Ifs and For-Next constructions to make them more easy to read. I placed some dummy data in cells B7:C26 and named that range "dailyarealog". Finally, I commented out the lines that started with "[valdaily..." because that appears to reference a non-existent object. Maybe a user form? I don't know. But once I did all that, the macro worked for me.
Below is the code I came up with. And below that is a link to the file I ended up with. I hope this helps.
[pre]
End Function
Sub processales()
Exit Sub
Dim reason As String, message As String, minstore As String, maxstore As String
sumofsales = 0
countofsales = 0
minsale = 99999#
maxsale = 0
maxsale = IIf(cursale > maxsale, cursale, maxsale)
If cursale < 500 Or cursale > 5000 Then
Next storesales
message = "we operated a total of " & countofsales & " stores today" & vbCrLf
message = message & "we made a total of " & Format(sumofsales, "$#,#.00") & vbCrLf
message = message & "max sales we had is " & Format(maxsale, "$#,#.00") & " from " & maxstore & vbCrLf
message = message & "min sale we had is " & Format(minsale, "$#,#.00") & " from " & minstore & vbCrLf
MsgBox message, vbInformation + vbOKOnly, "daily sale status- " & Format(Now, "dddd,mmmm,d,yyyy")
'    [valdailylogtitle] = "daily sales status- " & Format(Now, "dddd,mmmm,d,yyyy")
'    [valdailylogsummary] = message
'    [valdailylogtitle] = ""
'    [valdailylogsummary] = ""
[/pre]
https://docs.google.com/open?id=0B03QVPPcP2UwMUpTc0ZqS1BnTWc
