MSC Bobs
Hey everyone,
I’m having trouble doing something that used to be very easy for me. I’ve spent all day on the problem and haven’t been able to solve it and I would really appreciate some help.
The problem is that the counting formulas I like to use for some reason are not working. My preferred method of counting is to use IF statements nested in SUM so that I can filter.
I’m attaching two workbooks. The first one is called Programmer Validation. I purchased a data source and before the programmers were finished they sent me some sample files so that I could validate the data. On the calculation tab, you can see all of the different basketball statistics I’m tracking. I created quick and easy drop downs in cells B2 and B4 and then the matrix below updates. Beginning in cell B11 and going down, you can see how I use single-cell arrays with nested SUM(IF(
After I verified my data source was correct in the Programmer Validation workbook, I received the actual data, which is in the workbook Copy of Master Games. All of a sudden, nothing works.
Not even my normal trouble shooting is working. To trouble shoot, I replace references with hard codes and once I validate that, then I paste in the reference.
I’d appreciate if you guys can help me figure out what happened and why it’s not working anymore.
Thanks.
Thanks.
