Hello Bob, i would like to have macro code either using Vlookup or Match, finding exact matching value data in column A Part# sheet1 and Column A Part# sheet2, giving result True for matching, false for mismatch, or matched for Matching, false or mismatch in Columns D sheet1. if this can be help. i appreciated, Thank youEither VLOOKUP or MATCH, I'm not sure which. But I'd like to know more about what you're looking for. Do you need to know which rows are the same, or which are different, or which part-number/reference pairs aren't equivalent, or what? You just said "comparison" but didn't say what you need to know.
i can removed duplicates in Columns A and Columns B on both sheets to find matching Part# on 5000rows on each sheet, pretty much to this image.mhuy87
You're writing to compare column A's (Part#).
Is it matter - how many Part#'s are in both sheets?
eg if Sheet1 has 4 x Part# 108183300 and Sheet2 has 8 x Part# 108183300 - is that 'match' or not?
nothing changes.mhuy87
You seems to change Your output - me too.
I gotta use some other sample data.
Press [ Do It ] to get other sheets row if it matches.
... then You can see only matched Part#s.
this is what it showsmhuy87
Did You open my sample file?
Did You press [ Do It ]-button?
Did You get something to C-columns?
Nice, i see.mhuy87
As I wrote - if 'match' then You'll get other sheets row
eg cell A2 has 10 and c2 has 31 ... means there is a match and that match is in row 31.
eg cell A29 has 99 and c29 is empty ... means there is no match.
I may still not have this right, but it sounds here as though you want to be able to look down the rows in Sheet1, and for each part# in col A it should show in col D either True (if that part# appears one or more times in Sheet2!A:A) or False (if that part# doesn't appear anywhere in Sheet2!A:A). Is that right? You don't care which row(s) in Sheet2 have that part#, or how many rows?....finding exact matching value data in column A Part# sheet1 and Column A Part# sheet2, giving result True for matching, false for mismatch, or matched for Matching, false or mismatch in Columns D sheet1....
Thank you,mhuy87
TRUE/FALSE
> unique Part# Yes/No
Hi, is it possible to change Border Thick to multi random colors?mhuy87
TRUE/FALSE
> unique Part# Yes/No
Thank you very muchmhuy87
You've used one random color ...
This sample give more colors for those borders.
You can select which (Matched/UnMatched) You would like to see
as well as
You can select do You would like to see ALL or marked rows.
