VBS Problem auto-running VBA Macro
Happy New Year Everyone!
I am trying to run a macro through Task Scheduler. I have the following VBS file (in NotePad) saved as *.vbs and it errors out:
'Write Sheet's full path here
strPath = "C:General UseCopy Daily Files.xlsm"
'Write the macro name including module
strMacro = "Sheet1.Module1 Copy_Files_To_New_Folder"
'Create an Excel instance and set visibility of the instance
Set objApp = CreateObject("Excel.Application")
'objApp.Visible = False (disabled to be able to view activity)
'Open workbook; Run Macro; Save Workbook with changes; Close; Quit Excel
Set wbToRun = objApp.Workbooks.Open(strPath)
objApp.Run wbToRun.name & "!" & strMacro
''wbToRun.Save (disabled - Internal Macro Sequence provides for this function)
''wbToRun.Close (Ditto)
''objApp.Quit (Ditto)
'Leaves an onscreen message!
''MsgBox "Code Running Was Successful!", vbInformation (Not Required)
I get the following error:
Line: 13
Char: 1
Error: Cannot run the macro "C:General UseCopy Daily Files.xlsm!Sheet1.Module1 Copy_Files_To_New_Folder" The macro may not be available in this workbook or all macros may be disabled.
Code: 800A03EC
I know the marco exists and when I open the file it is in my trusted marco folder.
All I am looking to do have the macro run when I want it to run (Example, I was on vacation 12/31/12 and wanted the macro to run on 1/1/13 at 7:00 AM).
Any suggestions?
Thanks,
Mike
I have solved it.
Anyone who wants to autorun a macro can set it up in Schedule Task in Control Panel using the following code and save it using NotePad and RunMacro.vbs:
Dim xlApp, xlBook
Set xlApp = CreateObject("Excel.Application")
'~~> Change Path here to your workbook below
Set xlBook = xlApp.Workbooks.Open("C:General UseCopy Daily Files.xlsm", 0, True)
'Change the name of your macro below
xlApp.Run "Copy_Files_To_New_Folder"
xlBook.Close
xlApp.Quit
Set xlBook = Nothing
Set xlApp = Nothing
WScript.Quit
