VBA_Variable Problem
KishorKK
Hi All,
Can someone help me with this,
Sub test()
InputBox ("Enter your name")
x = InputBox("Enter first number")
y = InputBox("Enter second number")
MsgBox (x)
MsgBox (y)
MsgBox (x + y)
i'm getting this error!!
POST MOVED BY MODERATOR.
On the top of your code module..do you have
 OPTION EXPLICIT
written??
If yes, then you have to declare all your varaibles before you start using them in your code..
The solution would be, either remove
 OPTION EXPLICIT
on the top of your code module or declare the variables using
dim x as integer
dim y as integer
Hope this helps!!
