VBA Macro to customize Right Header
kimkiko
Hi! :-)
I have spent the last few days trying to make a macro in vba to customize the right header, in a excel sheet with multiple pages, but without much success. :-(
I need some help to do the following macro:
"In first right header page": N. M001 to M002
"In second right header page": N. M003 to M004
"In third right header page": N. M005 to M006
"In fourth right header page": N. M007 to M008
"In fifth right header page": N. M009 to M010
"In sixth right header page": N. M011 to M012
"In seventh right header page": N. M013 to M014
"In eighth right header page": N. M015 to M016
to the last page
Thanks in advance
Hi Kim ,
Can you write it on your own ? You need to do the following :
1. Set the print area manually.
2. Note down the number of printed pages that will result ; let us say it is 22.
3. Use a FOR ... NEXT loop in your macro , to print each page , one after another ; this can be done by using the Range.Printout method , specifying the page number in the first and second parameters.
4. Prior to issuing the Range.Printout statement , use the statement :
Worksheets("Sheet Name").PageSetup.RightHeader = "N. M001 to M002"
Of course , since you want this text to vary , you will have to ensure that the text is changed within the loop.
In case you are facing problems , let me know , and I can post the complete macro tomorrow ; it would help if you could upload your workbook , after erasing all data , retaining the print area and the printer settings such as lines per page , margins etc.
