VBA Macro help
Street Hunter
I need help in creating a Macro where:
  • I have to Select PAYMENTS Tab.
  • Filter Data in REFERENCE COLUMN with the name AXEL in ROW 5.
  • Assign Unique sequential INVOICE NMB to each filtered entry, for e:g (Comp-01, Comp-02)
Street Hunter
Try the following code:
Sub Filter_Assign_Values()
  'Setup
  Dim FilterStr As String
  FilterStr = "Axel"
  'Select Worksheet
  Sheets("Payments").Select
  'Clear Filter
  ActiveSheet.ShowAllData
  'Apply "Axel" Filter
  Dim rng As Range
  Dim lr As Long
  lr = Range("A" & Rows.Count).End(xlUp).Row
  Set rng = Range("A5:F" & lr)
  rng.AutoFilter Field:=2, Criteria1:=FilterStr
  'assign values to Filtereed data
  Dim cl As Range
  Dim x As Integer
  Set rng = Range("F6:F" & lr)
  x = 1
  For Each cl In rng.SpecialCells(xlCellTypeVisible)
  cl = "Comp-" & Format(x, "00")
  x = x + 1
  Next cl
or see the attached file
