vba how to copy data from one column by filtering each element from another column
joelmolina37
Hi All,
(Edit) New to the VBA world I am trying to make a vba script that filters each element from (checklist details) column B copies the result from column C removes duplicates and paste the name of the ref with hostname in another sheet. Thanks to anyone that can help.
According to your last attachment a VBA demonstration for starters :​
Sub Demo1()
        V = Sheet1.[A1].CurrentRegion.Columns("B:C")
        Sheet2.UsedRange.Offset(1).ClearContents
        For R& = 2 To UBound(V)
            S$ = .Item(V(R, 1))
            T$ = " " & V(R, 2) & " "
            If InStr(S, T) = 0 Then .Item(V(R, 1)) = S & T
            V = Application.Transpose(Array(.Keys, .Items))
           .RemoveAll
    With Sheet2.[A2:B2].Resize(UBound(V))
        .Borders.Weight = 2
        .HorizontalAlignment = xlCenter
        .VerticalAlignment = xlCenter
        .WrapText = True
        .Value = V
>>> use code - tags <<<
Sub STEP2()
    Dim V As Variant
    Dim R As Long
    Dim S As String
    Dim T As String
    V = Sheets("Checklist Details").Range("A1").CurrentRegion.Columns("B:C")
    Sheets("STIG HOST").UsedRange.Offset(1).ClearContents
        For R = 2 To UBound(V)
            S = .Item(V(R, 1))
            T = " " & V(R, 2) & " "
        .RemoveAll
    With Sheets("STIG HOST").Range("A2").Resize(UBound(V), 2)
        .Borders.Weight = 2
        .WrapText = True
        .Value = V
this was my edit so it can call to the certain sheet on the doc thanks for all this was great.
This is the sort of thing that Power Query (built in to Excel) can do without VBA.
See the table in cell D1 of the EXAMPLE OF OUTPUT REQUESTED sheet of the attached workbook.
It updates (by refreshing) like you would a pivot table after changing the data in the source table.
