GauravS313530
Below is the macro for share the filtered data on Mail body but I am unable to modify this to share the same as excel attachment also along with on mail body.
I am new in VBA. please help.
>>> use code - tags <<<
>>> use code - tags <<<
Sub mailK()
'https://chandoo.org/forum/threads/vba-to-filter-data-based-on-column-and-copy-to-the-body-of-the-mail.45912/
Dim Wks As Worksheet
Dim OutMail As Object
Dim OutApp As Object
Dim myRng As Range
Dim list As Object
Dim item As Variant
Dim LastRow As Long
Dim uniquesArray()
Dim Dest As String
Dim strbody
Set list = CreateObject("System.Collections.ArrayList")
Set Wks = ThisWorkbook.Sheets("Deal Info")
With Application
.EnableEvents = False
.ScreenUpdating = False
With Wks
For Each item In .Range("E2", .Range("E" & .Rows.Count).End(xlUp))
If Not list.Contains(item.Value) Then list.Add item.Value
For Each item In list
Wks.Range("A1:F" & Range("A" & Rows.Count).End(xlUp).Row).AutoFilter Field:=5, Criteria1:=item
LastRow = Cells(Rows.Count, "A").End(xlUp).Row
Set myRng = Wks.Range("A1:C" & LastRow).SpecialCells(xlCellTypeVisible)
Dest = Cells(LastRow, "F").Value
strbody = "Dear ," & "<br>" & _
"See the list of deals" & "<br/><br>"
With OutMail
.To = Dest
.CC = ""
.BCC = ""
.Subject = "Deals"
.HTMLBody = strbody & RangetoHTML(myRng)
.Display
'.Send
On Error GoTo 0
Wks.ShowAllData
On Error GoTo 0
With Application
.EnableEvents = True
.ScreenUpdating = True
Function RangetoHTML(myRng As Range)
Dim TempFile As String
Dim TempWB As Workbook
Dim fso As Object
Dim ts As Object
Dim i As Integer
TempFile = Environ$("temp") & "\" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
myRng.Copy
Set TempWB = Workbooks.Add(1)
With TempWB.Sheets(1)
.Cells(1).PasteSpecial Paste:=8
.Cells(1).PasteSpecial xlPasteAllUsingSourceTheme, , False, False
.Cells(1).Select
.DrawingObjects.Visible = True
.DrawingObjects.Delete
On Error GoTo 0
For i = 7 To 12
With .UsedRange.Borders(i)
.LineStyle = xlContinuous
.ColorIndex = xlAutomatic
.TintAndShade = 0
.Weight = xlMedium
With TempWB.PublishObjects.Add( _
SourceType:=xlSourceRange, _
Filename:=TempFile, _
Sheet:=TempWB.Sheets(1).Name, _
Source:=TempWB.Sheets(1).UsedRange.Address, _
HtmlType:=xlHtmlStatic)
.Publish (True)
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
RangetoHTML = ts.readall
ts.Close
RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
"align=left x:publishsource=")
TempWB.Close savechanges:=False
Kill TempFile
Set ts = Nothing
Set fso = Nothing
Set TempWB = Nothing
End Function
