Skeeeter56
Hi all the following code prints 4 print jobs 1 after the other, this all works well.
I also have each of the 4 print jobs setup as a single print job.
I am sure there is a simpler way to do this using 1 block of code.
Here is 1 of the single print jobs code
I am sure this code can be made much better, it all works as is.
Private Sub cboPrint_Click()
Dim pwd As String
pwd = "post"
Sheets("NBC").Unprotect Password:=pwd
Sheets("NBC110").Unprotect Password:=pwd
'Printout for NBC110
Worksheets("NBC").Range("H18").Value = Worksheets("NBC").Range("I9") 'Set this to First Row of Data sheet where NBC's start
Worksheets("NBC").Range("H19").Value = Worksheets("NBC").Range("I10") 'Set this to Last Row of Data Sheet where NBC's End
Worksheets("NBC110").Activate
PrintFormsNBC
Sheets("EVEE").Unprotect Password:=pwd
Sheets("EVEES").Unprotect Password:=pwd
'Printout for Evee's
Worksheets("EVEE").Range("H18").Value = Worksheets("VAN").Range("I9") 'Set this to First Row of Data sheet where VAN's start
Worksheets("EVEE").Range("H19").Value = Worksheets("VAN").Range("I10") 'Set this to Last Row of Data Sheet where VAN's End
Worksheets("EVEES").Activate
PrintFormsEVEES
Sheets("VAN").Unprotect Password:=pwd
Sheets("VANS").Unprotect Password:=pwd
'Printout for Van's
Worksheets("VAN").Range("H18").Value = Worksheets("VAN").Range("I9") 'Set this to First Row of Data sheet where VAN's start
Worksheets("VAN").Range("H19").Value = Worksheets("VAN").Range("I10") 'Set this to Last Row of Data Sheet where VAN's End
Worksheets("VANS").Activate
PrintFormsVANS
'Openform and await the OK button to resume
ChangeNBCPaper.Show
Sheets("EAMB").Unprotect Password:=pwd
Sheets("EAMBS").Unprotect Password:=pwd
'Printout for Eamb's
Worksheets("EAMB").Range("H18").Value = Worksheets("EAMB").Range("I9") 'Set this to First Row of Data sheet where NBC's start
Worksheets("EAMB").Range("H19").Value = Worksheets("EAMB").Range("I10") 'Set this to Last Row of Data Sheet where NBC's End
Worksheets("EAMBS").Activate
PrintFormsEAMB
'Protect sheets
Sheets("NBC").Protect Password:=pwd
Sheets("NBC110").Protect Password:=pwd
Sheets("EVEE").Protect Password:=pwd
Sheets("EVEES").Protect Password:=pwd
Sheets("VAN").Protect Password:=pwd
Sheets("VANS").Protect Password:=pwd
Sheets("EAMB").Protect Password:=pwd
Sheets("EAMBS").Protect Password:=pwd
Worksheets("Menu").Activate
Private Sub CommandButton2_Click()
Dim pwd As String
pwd = "post"
PrintFormsNBC
