vba code required to delete zero (0) in range
rahulshewale1
Dear sir,
Please fidn the attached sheet. i want to delete zero column a,column b,column c.
if i select any column zero will delete with vba button
Rahul shewale
Please explain a little more clearly. If you select column A, then do you wish to delete the whole column or just the row containing the zero value or something else. How do you wish to select the column? Input Box? Unfortunately, we are not mind readers here and you really need to explain in detail what you wish to accomplish.
Attach this code to a button
Sub del0()
    Dim lr As Long
    lr = Range("A" & Rows.Count).End(xlUp).Row
    Dim col As String
    col = InputBox("Which column do you wish to review?")
    Dim i As Long
    For i = 1 To lr
        If Cells(i, col) = 0 Then Cells(i, col).ClearContents
