VBA code for deleting rows, using Name
Need a help, I need a VBA code for deleting rows from the table in Sheet Temp excluding status mention in Sheet Select
Status Mention in Sheet Select may change time to time (may increase or decrease also), so i was trying to use Name function, but unable to do so
  • Need Help.xlsx
Try
Sub test()
    With Sheets("temp").Cells(1).CurrentRegion
        .Parent.Select
        .AutoFilter 26, Application.Transpose(Sheets("select").Cells(1).CurrentRegion.Columns(1)), 7
        .SpecialCells(12).EntireRow.Select
        .AutoFilter
        Selection.EntireRow.Hidden = True
        .SpecialCells(12).EntireRow.Delete
        .EntireRow.Hidden = False
        On Error GoTo 0
        .Cells(1).Select
