Using Right Left formula-Need help!
Dear Friends,
Require help in the attached file to extract state, pincode and name of the client.
I am unable to get state and name of the client
Thanks for the help in advance.
Gaurang
Hi Gaurang,
How would excel recognize where is Name of client, states etc? as there is no clue.
1 or more thing should be constant to get result.
Hi Khalid,
I forgot to mention in earlier post, actually need address from Branch address column and also state. i could extract pincode with help of right formula. Want to know formula which will extract address and state. before state is the address, that i want to extract for address. Then comes state and pincode.
is it possible?
Thanks!
Gaurang
Just try it
For Addresses:
=LEFT(TRIM(SUBSTITUTE(A1,","," ")),FIND("qq@",SUBSTITUTE(TRIM(SUBSTITUTE(A1,","," "))," ","qq@",LEN(TRIM(SUBSTITUTE(A1,","," ")))-LEN(SUBSTITUTE(TRIM(SUBSTITUTE(A1,","," "))," ",""))-1))-1)
For State:
=LEFT(TRIM(RIGHT(SUBSTITUTE(A1,",",REPT(" ",60)),120)),SEARCH(" ",TRIM(RIGHT(SUBSTITUTE(A1,",",REPT(" ",60)),120)),1)-1)
Hope it works
Hi Gaurang,
Check this for Address:
=LEFT(C10,FIND(B10,C10)-1)
i tried it on C9,10 & 11
Hi Khalid,
Thanks for the reply.
Just checked for pincode, i had entered Right formula bt it is not working as in some cells it is capturing 5digit numbes. so is there a formula which will capture pincode accurately.
Also the above formula which you have mentioned is working well. but since there are like 5000 address thus in some cases it is showing as #value. as the format is not uniform. but i will save the formula for future reference. Thanks alot for the help! :)
Gaurang
Just try it
For Addresses:
For State:
Hope it works
Hi Azumi,
It is working for state, but for address in end it is capturing few letters of state.
For eg:
4TH FLOOR RAJESWARI BUILDING 503 4'TH FLOOR SHALIMAR COMPLEX ( OPP C M I ROAD SHALIMAR COMPLEX JAIPUR
2 ex: FIRST FLOOR 176 A/5 K R AUTOMOBILE BUILDING TRIVANDRUM HIGH ROAD NEAR KODAI CAR M 7M DEALER TIRUNELVELI TAMIL
Jaipur and Tamil is getting captured in address which is state.
Appreciate your efforts for this.Thanks a lot for the help.
Gaurang
