Using custom number prevent zero and negative values being displayed
reddwarf4ever
Using custom number prevent zero and negative values being displayed.
I have a simple worksheet, which I want to hide negative and zero results.....
I found this for hiding zero value cells only ........0;-0;;@
Is there a simple way of working out myself how to hide or change various aspects of cells....colour etc and also how to group actions.
There are 4 part in Custom Number Formatting..
Positive ; Negative ; Zero ; Text
You can hide any of this... in you case.. use formatting as
which is.. hiding below two parts..
Hi
Thanks, that looks interesting.....i assume then that the ; acts as a block for each field....the # and @ are just open and close symbols.....or I could be wrong LOL
Is there a way of including this but also hiding error values also, or could this be handled differently ?
I tried iferror, but had some strange results....also want the cells to have % value, .dont know if this can be added to #;;;@ or not
Ps will look at link supplied by old chippy.....
# is for.. Any Number..
so for example Number Format is 00.00%;;
if you use 00.00% it will display 2 digit after and before Decimal and a %age sign.
If you write 9 it will display as 09.00% and because you are forcing it to show 2 digit before decimal.
and if you write 112, it will display as 112.00% as excel forcing it to show complete value.
# is not outer format.. just the way you have entered thenumber..
try custom number format 0.00%; ;
If the numbers you want to hide are the results of formulas, then you could use something like this to hide zero's, minus numbers and errors
=IFERROR(IF(A1<=0,"",A1),"")
