Please someone help me fix this issue it is giving me error,
Run-time error '1004':
application-defined or object-defined error
code below this line. Thanks again
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
Dim dccolumn As Integer
Dim dcvalue As String
dccolumn = ActiveCell.Column
dcvalue = ActiveCell.Value
If Application.Intersect(ActiveCell, [headers]) Is Nothing Then
If ActiveCell.Value <> "" Then
ActiveSheet.Range("a:j5000").AutoFilter Field:=dccolumn, Criterial:=dcvalue
Dim rownumber As Integer
rownumber = ActiveCell.Row
Range("a4:j5000").Interior.ColorIndex = xlNone
Range("a" & rownumber & ":j" & rownumber).Interior.Color = RGB(255, 255, 9)
