PP3321 Active Member Jun 10, 2016 #1 I want to remove this part IFERROR( ,"") in my formula. Is such thing possible? I am looking for ways (Macros or otherwise) to do it automatically as there 300 formulas containing IFERROR in my workbook!!! Thank you!
azumi Active Member Jun 10, 2016 #2 you can use find and replace, even if u try to replace part of formula or full formula, that is simple way and efficient, just try it
PP3321 Active Member Jun 10, 2016 #3 @azumi Thanks. I tried but it does not work. It says Excel cannot find a match...
PP3321 Active Member Jun 10, 2016 #4 I want to remove comma, "" and closing bracket also. So that it will be just left with mathematical formula...A2/1A
N NARAYANK991 Excel Ninja Jun 10, 2016 #5 Hi , See if this helps : http://chandoo.org/forum/threads/find-replace-around-reference.29718/#post-177695 Narayan
PP3321 Active Member Jun 10, 2016 #6 OK thank you!!!! Sorry I could not find your previous solution. I will break it down and do replace as you suggest...
