Power Query, Pivot every alternate row
chriscorpion786
In the custom column, I have store names and every alternate row contains the word T&F, I need to pivot the rows where T&F along with the "Yes/No" in the value column.
The end result should read:
CustomValueT&F
Dubai Mall-DM1-1404YesNo
Much appreciated for a solution in Power Query, file is attached.
Thanks,
Mustafa
  • Store Names.xlsx
By the way, I have posted the same question in Mr.Excel forum as per the link below:
Thanks Frank, it worked. Great!
The Combined step is where you have used a custom function, could you explain that, bit difficult for me to decipher it.
Is there no UI method through Power Query that we can do this ?
Starting with the user interface is perfectly normal, but it’s important to realize how powerful the M language can be for processing and modeling data. Some tasks are either very complex or simply not possible through the interface alone, so I encourage you to get comfortable with M.
I’m sharing a new, simpler solution that still involves some M code, but it’s easier to follow and I’m confident you’ll understand it without any issues. I’ve also included a detailed step-by-step explanation. I hope this helps!
Best Regards
1. Load the table
Source: Loads your Excel table named "Table1" into Power Query.
2. Convert all columns to text
ChangeType: Makes sure all columns are treated as text (avoids number/date issues).
3. Unpivot columns
Unpivot: Converts columns (except product details) into rows:
  • Attribute: Name of the original column (e.g., "T&F", "Dubai Mall-DM1- 1404", etc.)
  • Value: Value from the original cell
4. Add a 'Custom' column to tag T&F
AddCustom: Adds a new column called "Custom". If the attribute name contains "T&F", the value is "T&F"; otherwise, it keeps the attribute name.
5. Remove the old 'Attribute' column
RemoveAttr: Deletes the "Attribute" column—now you use "Custom".
6. Reorder columns for clarity
Reorder: Rearranges columns for easier reading.
7. Add an index
AddIdx: Adds a unique row number (index) to each row, starting from 1.
8. Add a group number
AddGrp: Adds a "Grp" column that groups every two rows together:
  • Rows 1-2: Grp 0
  • Rows 3-4: Grp 1
  • and so on
9. Separate odd and even rows
Odd: Gets the odd-numbered rows (first row in each pair).
Even: Gets the even-numbered rows (second row in each pair).
10. Join odd and even rows by group
Join: Combines each odd row with its matching even row (same group number).
11. Expand the joined even row’s Value column
ExpandEven: Adds the "Value" from the even row to the odd row, names it "T&F".
12. Remove temporary columns
RemoveTmp: Deletes "Idx" and "Grp" columns, which you no longer need.
Result:
Each row now includes original info, the "Custom" column, the value from the odd row, and the "T&F" value from the paired even row
  • Store Names v3.xlsx
Brilliant & Super helpful. I went through each step line by line, debugging, understanding and learning at the same time from your file and your steps mentioned here.
Thank you Frank!
