Need help with simulation macro
GRODD
I have a macro and need some help. I want to play a game and have this macro If you place a E or O in I J 3, U or D in T U 3, U or D in AE AF 3, E or O in I J 11, U or D in T U 11, U or D in AE AF 11, E or O in I J 19, a U or D in T U 19 and a U or D in AE AF 19, E or O in I J 29 and 32 and a U or D in T U 29 and 32 and a U or D in AE AF 29 and 32 it should ONLY leave you with 1 to 3 max numbers for each ball. You just have to figure out which pattern to play per ball that leaves only 1 to 3 numbers per ball in AI AJ AK AL AN. For some reason, I cannot get it to display on a separate sheet what those numbers are left to display. It was placing them over in sections BV and BW. BX.....
I am NOT a macro writer and need someone to actually change this for me to do what i am asking. Thank you so much. I tried to upload the file and it would not allow that so i uploaded a snip. Thank you in advance
Could You explain below with other words ... to get some kind of image ... what?
Where is You named a separate sheet?
Your file has one sheet.
What the workbook does, and i hope this makes sense.
Each Game sheet contains:
9 pattern groups
Three Even/Odd (E/O) sections
Three Up/Down (U/D) sections
Bonus Ball sections
For every game, there are 9 binary decisions:
3 Even/Odd groups
6 Up/Down groups
Each decision can be one of two values:
E or O
U or D
That produces 512 possible combinations (2^9).
What I want the macro to do
For every one of the 512 combinations:
Clear all previous E/O and U/D entries.
Fill the proper worksheet cells with one complete combination.
Force Excel to recalculate all formulas and conditional formatting.
Read the resulting candidate numbers for:
Ball 1
Ball 2
Ball 3
Ball 4
Bonus Ball
Count how many candidate numbers remain for each ball.
Save the results to a new worksheet.
Example output:
Combo Pattern Ball1 Ball2 Ball3 Ball4 Bonus
147 UDUDEOUEO 17 20,24 28 31,34 8
The problem
The macro correctly creates the output worksheet, but no combinations are written.
I either get:
only the column headers
or
Every combination reports zero surviving numbers.
The workbook itself works correctly when I manually enter E/O and U/D values.
So the issue appears to be the VBA reading the results after calculation.
My question
What is the best VBA method to capture the displayed surviving numbers after formulas and conditional formatting updates?
Should I be reading:
the formula results,
DisplayFormat,
SpecialCells,
conditional formatting,
another approach?
... with other words ...
I understood that - There needs to be three columns (i, t, ac) for those Your six columns (i-j, t-u, ac-ab).
As You wrote that You've some challenges with macros ... I'll skip those.
Why do You've a lot of conditional formatting and ... a lot of same kind of formulas?
... my opinion is that columns from A to AO are needed.
Your previous post told:
Example output:
Where can I find that from Your sample file?
