Need help with an excel formula
Rose Rodney
I'm trying to calculate scores on a spreadsheet. These scores when accumulated totals100. However there are instances when a score criteria may have equal a not applicable value, this should not affect the overall end score. Example 25+25+25+n/a+25=75/75 or 100%. Is there a way for me a achieve this formula?
In B7 of the attached worksheet the formula is entered Ctrl-Shift-Enter ...
There is something awry with your description - I don't think
"25+25+25+n/a+25=75/75" is correct, but should be 100/100?
  • RR-DME.xlsx
When you add cell values using the + sign , then there is a problem with text values.
However , if you use the SUM function , this ignores text values and adds only the numbers.
Thus , if your values have the text string N/A , it will be ignored by the SUM function ; error values such as #N/A will still be a problem. For such values , you will have to use the technique posted by Evans.
Hi @Rose Rodney welcome to the forum :awesome:
Using David's file, another option (normal entered formula), if there is no minus value:
=SUMIF(A2:A6,">0")
and this, if there are minus values:
=SUM(SUMIF(A2:A6,{">0","<0"}))
