DashboardNovice
I am using the following article as a guide:
http://chandoo.org/wp/2009/07/09/project-milestones-in-timeline/
I'm working on the 2nd tab in the attached spreadsheet. See columns T thru AC. Actual milestones completed are in red. Future milestones yet to be completed are in green.
First I plotted the actuals. Everything seemed to be fine. See the 2nd graph. Notice how nothing was graphed beyond Milestone 7. This is exactly what I want.
But then I ran into problems when I added the data from the Future Milestone Estimates in green. The result appears in the first graph.
1. I don't want to show the green labels in the black rectangle. I don't want to show the red labels in the black rectangle either. Is there a way to do this?
2. I'm still trying to understand when Excel ignores #N/A errors and when it doesn't.
3. Notice the formula in the blue cells in AC7:AC13. These should be evaluating to TRUE. But instead of returning a blank, I get an #N/A error. Why is this?
If I were to guess what is happening I would say this. After I copy and paste the height column of the actuals, I change the X axis labels to the Milestones in column Y. So far, so good. Then I copy and paste the height column of the Future Milestones. Then I also change the X axis labels to the Milestones, this time the Milestones in column AB. At this point is appears as if the latest X axis labels, supersedes the previous ones. This seems to be the basis of the problems I am running into.
Also, can anybody recommend any articles I can read about how changing the X axis labels affects the graph?
