Hi, I have a data set that is just random numbers in column A between 0-99, but there are also some blanks because there were no readings from the raw data when it was taken. But these are not true blanks, they are like a "" so read as text?
In column B I have criteria "A", "B", or "C"
To find the maximum value for "A" I would normally write
=sumproduct(max((A2:A100)*(B2:B100="A")))
But due to the "blanks" in column A, it throws a #value error. How can I filter out these errors and still get the correct answer?
(note - I could clean up the data with a new column to make any non-number cells = 0, but I have 188,000 rows of data and I dont really want to add another column - prefer to do it in the formula if possible)
Thanks, Oxi
Thanks, Oxi
