is it possible to compare columns of defferent excels with Index and match functions?
Hi all,
is it possible to compare columns of similar type e.g. products from different excels using the Index and Match functions or they have to be in the same excel?
Example:
I have 2 excels. Each excel has 1 column with product names.
Do i have to merge them in order to use Index and Match functions to compare the columns?
Thank you for your time reading this.
Regards.
Hi, the_observer!
Give a look at the uploaded files.
The formula used at the Excel1.xlsx workbook is:
=SI.ERROR(COINCIDIR(A2;[Excel2.xlsx]Hoja1!$A$1:$A$6;0);"No") -----> in English: =IFERROR(MATCH(A2,[Excel2.xlsx]Hoja1!$A$1:$A$6,0),"No")
Regards!
I see.
So it is only a matter of syntax to direct the formula to look at the other excel.
Thank you very much for your answer SirJB7.
Regards.
Hi, the_observer!
Glad you solved it. Thanks for your feedback and welcome back whenever needed or wanted.
Regards!
