Dan Hollingworth
Hello all,
New to the site, I've used the site a lot over the years but never posted, so this must mean I'm stuck, and would appreciate your help! So here goes...
I'm not sure what function I need to use to get the required outcome, some sources I read say Index and Match would be the one, but others have also been suggested.
My issue relates to the below:
I want to insert a function into cell C2 that will automatically select the correct value from the table on the right when I enter data into the cells in A2 and B2. For example the data I have entered in cells A2 and B2 should target cell G6 and display its value in C2.
I don't know if this can be done because of the way the table is set out, obviously the weights are ranges and I just don't know how to make it work.
Any advice would be greatly appreciated
Cheers
Dan
Cheers
Dan
