How to place borders from one plan to another Plan
Hello SPP,
You could try this:-
Sub Test()
Plan1.Range("B4:B10").Borders().LineStyle = Plan2.Range("B4:B10").Borders().LineStyle
I hope that this helps.
Cheerio,
vcoolio.
vcoolio
Good Morning!
Thank you for your help
But stay with continuous line
I would spend with the same border style
Hello SPP,
I don't understand your meaning. Your opening post asks how you could copy the borders in the range B4:B10 from Plan2 to Plan1.
The little piece of code in post #2 does exactly that.
I've attached your sample workbook with the code implemented and assigned to the "TEST" button in Plan1. Have a look at the borders in Plan2 B4:B10 then go to Plan1 and click on the button. You'll see the same borders copied to the same range in Plan1.
Cheerio,
vcoolio.
Hi !​
Via Excel basics : Copy the source range and on the destination range Paste Specials the format only,​
so easy just activating the Macro Recorder …​
Hello SPP,
No, they don't. You have what you asked for (copying the borders B4:B10) so you've just confused everyone here with your changing requests!
Cheerio,
vcoolio.
