How to delete rows when a column does not start with certain numbers?
Hi, I have a big set of trade stats of more than 50000 lines.
I want to keep only certain lines when column B starts with certain numbers.
For the below that I found online, it will only keep lines starting with 29.
I need to keep lines if column B has numbers starting with 292, 293 and 350. Please advise
Sub DeleteRowsNotStartingWith29()
  Columns("B").Replace "29", "=29", xlPart
  Columns("B").SpecialCells(xlConstants).EntireRow.Delete
  On Error GoTo 0
  Columns("B").Replace "=29", "29", xlPart
Hi @powerpivot beginner
Maybe something like this (I am assuming you have headers so range would start in line 2):
Sub deleterows()
    Dim lastrow, i As Integer
    lastrow = Columns(2).Cells(Rows.Count).End(xlUp).Row
    For i = 2 To lastrow
        If Left(Cells(i, 2), 3) <> 292 And Left(Cells(i, 2), 3) <> 293 And Left(Cells(i, 2), 3) <> 350 Then
            Cells(i, 2).EntireRow.Delete
Hope this helps
Change to
    Dim x, e
    x = Array("292", "293", "350")
    For Each e In x
        Columns("B").Replace e, "=" & e, xlPart
    On Error GoTo 0
    For Each e In x
        Columns("B").Replace "=" & e, e, xlPart
Thanks everyone for reply.
What if instead of deleting rows if a column does not starting with certain numbers, I want to delete rows if a column does not contain certain words, how should I revise the code? I am only keeping the row if
column E contain words starting with glu or citi. Thanks
  Dim x, e
  ForEach e In x
  OnErrorResumeNext
  OnErrorGoTo 0
  ForEach e In x
EndSub
Try
    Dim x, e
    x = Array("city", "glu", "292", "293", "350") '<- alter to suite
    For Each e In x
        If IsNumeric(e) Then
            Columns("E").Replace e, "=" & e, xlPart
            Columns("E").Replace e, "=""" & e & """&", xlPart
    On Error GoTo 0
    For Each e In x
            Columns("E").Replace "=" & e, e, xlPart
            Columns("E").Replace "=""" & e & """&", e, xlPart
When I tried the below, all the rows got deleted.Just to clarify, I just need to
work on Column E. If Column E contains any words starting with citi or glu, the lines should remain. Likewise, all the rows should be deleted so I will be left with rows where there the keywords I am looking for is in Column E.
  Dim x, e
    x = Array("city", "glu", "292", "293", "350") '<- alter to suite  ForEach e In x
      EndIf
  OnErrorResumeNext
  OnErrorGoTo 0
  ForEach e In x
      EndIf
EndSub
Thanks for your help. I am attaching a sample. These are public exports stats of a certain country. I am looking for records of certain items ( but more than 50000 records per month).If in column E, it contain certain items containing certain words, eg citi or glu, then I want to review them. If not, they can be deleted. And I hope to keep the header row 1.
OK, 50000 rows... AdvncedFilter would be the best
    Dim rng As Range, x
    x = Array("citi", "glu")
    With Cells(1).CurrentRegion
        Set rng = .Offset(, .Columns.Count + 2).Cells(1).Resize(2, UBound(x) + 1)
        .Range("e1").Copy rng(1).Resize(, UBound(x) + 1)
        rng.Rows(2).Value = x
        rng.Rows(2).Value = Evaluate("""<>""&" & rng.Rows(2).Address & "&""*""")
        .AdvancedFilter 1, rng
        .Offset(1).EntireRow.Delete
        .Parent.ShowAllData
        On Error GoTo 0
Thanks for your help. But I tried it. It will only keep the lines starting with "citi" and "glu". Sometimes the words starting with "citi" and "glu" are in the middle of the goods description and the code do not effectively capture them. Anyway to change words starting with "citi" and "glu" in Column E to words containing "citi" and "glu" in Column E?
Then change
to
rng.Rows(2).Value = Evaluate("""<>*""&" & rng.Rows(2).Address & "&""*""")
