Help!
MissHJL
Hi there,
I am working on a spreadsheet that I have so far managed to get to run smoothly using formulas. Unfortunately, without using a stupidly complicated formula in each individual cell, I am now stumped.
I am trying to get the information from the "Selections" tab, copies into the "Sheet 1" Tab, but only the catagories in "Sheet 1".
I know that I will probably need a VBA but I don't have any experience in this, and whilst I am trying to learn, I need to get this done ASAP for work.
I've attached the spreadsheet.. if anyone can help and guide me as to how to insert a VBA that will do what I need it to do, that would be SO helpful!!
Thank you!!
Hi:
What are you trying to achieve here, please give more background as far I can see you are trying to pull the same info to a different tab but with fewer columns than your Selections tab.
Nebu
I need the information (that is seen on "Sheet One") to populate from the Selections Tab as long as "Confirm Hire" is ticked "Yes".
If it's ticked No, I don't want it to be populated.
Can I ask for a link to learn how to use pivot tables?
Thank you so much!! How do I refresh the table so that I can keep adding lines if I need to?
