Help with VBA copying and inserting a header!
Teatimedgg
Hey Everyone,
Newby here! I have a multiple columns of data but i want to insert a header line (1st line -range A2.H2) when the word Dog-A changes in Column C i want this to continue until the end of data in column c
Example:
HABC companyHeader1234512312345012
LABC companyDog***xUnit1
LABC companyDog***xUnit119.03
LABC companyDog-A***xUnit1200
LABC companyCat***xUnit170
LABC companyCat***xUnit115000
Any help would be appreciated!!! Thank you!
Can you upload a workbook which shows your data as it is in one tab , and as it should be after the macro runs , on another tab ?
Hi:
Something like this?
Sub test()
Dim Rng As Range
i& = Sheet3.Cells(Rows.Count, 1).End(xlUp).Row
Set Rng = Sheet3.Range("A2:H" & i)
For j& = Rng.Rows.Count - 1 To 2 Step -1
    If Rng.Cells(j, 3).Value = "Dog-A" Then
        Rng.Cells(j + 1, 1).EntireRow.Insert
        Range("A2:H2").Copy
        Range("A" & k & ":H" & k).PasteSpecial
    k = j + 1
Another option :
Public Sub InsertHeader()
          Dim Headerrow As Range, rw As Range
          Dim lastrow As Long
          With Me
                If .AutoFilterMode Then .Cells.AutoFilter
                Set Headerrow = .Range("A2:H2")
                Headerrow.Font.Bold = True
                lastrow = .Range("A" & Rows.Count).End(xlUp).Row
                With .Range("A2:H" & lastrow)
                    .AutoFilter Field:=Application.Match("Header", Headerrow, 0), Criteria1:="Dog-A"
                    Set filtereddatarange = .SpecialCells(xlCellTypeVisible)
                If filtereddatarange Is Nothing Then Exit Sub
                With filtereddatarange
                    For Each rw In .Rows
                        With rw
                              If .Address <> Headerrow.Address Then
                                .Offset(1).EntireRow.Insert
                                .Offset(1).Value = Headerrow.Value
                                .Offset(1).Font.Bold = True
                .Cells.AutoFilter
                .Columns.AutoFit
That can only happen if you have copied the code and pasted it into a code module , instead of a Sheet section.
Paste the code in a Sheet section , the worksheet where your data is.
If your data is in a sheet named Sheet5 , paste the code into the Sheet5 section in your VBE.
You can always retain the code in a code module , by replacing all references to the Me keyword with the ActiveSheet keyword. You will have to ensure that you make the sheet which has your data the active sheet before you run the macro.
Ok updated With Me to With ActiveWorkbook.Worksheets("GP UPLOAD"). I changed the Dog-A name to the correct name and I get error ; autofilter method of range class failed - UGH I appreciate your help
I am sorry , but unless you can upload your actual workbook , I cannot help.
Is the column header label Header ? If not , you need to change the highlighted words in the following line of code :
If after this change , it still does not work , please upload your working file.
Can you clarify at what point the header values should be inserted ?
Is it after the lines which have MEDIA in the Header column , or is it after the lines which have CORP-MMF in the Header column ?
It is after CORP-MMF. I ran the other code, and if I only have 15 lines it work. I the amount of rows will always be different. Can it keep going until the end of data?
