Help..Vba-Filter and Paste Unique Values to New Sheets
Hello All,
I need help here.... I have a set of data where I filter a criteria and copy paste in different sheets of the same work book.
Now the challenge is :
If you run the macro more than once, the error would occur as sheets already exist. Is there any workaround
where in I need to delete all the created sheets created by the macro and then re run the code again.
Sub filter()
Dim x As Range
Dim rng As Range
Dim last As Long
Dim sht As String
Dim wS As Worksheet
sht = "DATA Sheet"
last = Sheets(sht).Cells(Rows.Count, "F").End(xlUp).Row
Set rng = Sheets(sht).Range("A1:F" & last)
Sheets(sht).Range("F1:F" & last).AdvancedFilter Action:=xlFilterCopy, CopyToRange:=Range("AA1"), Unique:=True
For Each x In Range([AA2], Cells(Rows.Count, "AA").End(xlUp))
With rng
.AutoFilter
.AutoFilter Field:=6, Criteria1:=x.Value
.SpecialCells(xlCellTypeVisible).Copy
Sheets.Add(After:=Sheets(Sheets.Count)).Name = x.Value
ActiveSheet.Paste
Next x
Sheets(sht).AutoFilterMode = False
With Application
.CutCopyMode = False
.ScreenUpdating = True
Appreciate your assistance here. Attached worked file for your reference.
