Help Regarding a VBA Code for Checking the links (Dead Active)
ajayxlnc
I have 2 categories of links with me. Column A is one category of Web Links and in Column B there is a list of other category links.
1) I want to check whether the links are active or dead links.
2) I want to match the content of both the web pages in the back end or even in the front end. If the content in both (Column A & Column B) links are matching then it should return some value stating that as "Yes - If it matching", "No - If it is not matching".
Is this possible with a Excel Macro or is there any work around for this kind of task. Please help me out in this Issue
Based on the number of similar requests for this type of work at odesk.com, and my own knowledge of VB, I do not think this is possible (especially with web links). However, if you check at odesk, you could probably hire someone to do this for you for < $10.
Ajayxlnc
I have answered two posts on this before
Have a look at:
http://chandoo.org/forums/topic/broken-links-in-excel-2007
http://chandoo.org/forums/topic/check-broken-external-hyperlinks
See if they help you out
