I inddon Member Nov 15, 2014 #1 Hello There, I have a formula which adds time. This total of time can exceed 24 hours. Somehow this doesn't work as expected: I have attached the sample workbook. Could you please advise? Thanks & regards Don Attachments Total all times.xlsx 9.5 KB · Views: 3
N NARAYANK991 Excel Ninja Nov 15, 2014 #2 Hi Don , Without looking at your file , my first guess would be the cell format ; when the total time exceeds 23:59:59 , the format has to be : [h]:mm:ss to display the hours of 24 and more. Narayan
Hui Excel Ninja Staff member Nov 15, 2014 #3 Select the Total cells Ctrl 1 Apply a Custom Number format of [h]:mm
I inddon Member Nov 15, 2014 #4 NARAYANK991 said: Hi Don , Without looking at your file , my first guess would be the cell format ; when the total time exceeds 23:59:59 , the format has to be : [h]:mm:ss to display the hours of 24 and more. Narayan Click to expand... Hello Narayan and Hui, I applied hh:mm to the cell, and wondering why is it not working, then came the truly ExcelNinjas . Thank you for your solution. Amazing '[]' sign makes so much difference. Could you please mark the post as [SOLVED] for me Regards Don
