Joris Hermans
Hello there you all.
I've been cruisin' the internet for a solution to my problem, but didn't find something usefull. I'm quiete sure someone at Chandoo forum can (will) help me out.
I have an Excel (2010) containing an overview of project budgets and invoices.
On a dashboard, I need to show the number of projects that are over budget. This array formula seems to do the trick; ==> {Sum(If(Invoice>Budget;1;0)}
But I also need to show the amount that is over budget ==> if Invoice > Budget then calculate difference and add to total. (if under budget do NOT add to total)
Constraints:
I prefer NOT to add an extra column (I-B), but would like to have the calculation on the fly in one single (array?) formula
I prefer to use namde references (using tables and table-columns) instead of A1 references.
The file attached gives overview of what I already have and what I need.
Hopefully one can help me out over here?
Constraints:
