finding second occurrence is not working - HELP!
allanppark
Hey guys,
I've been working on this macro, which brings data from the website crunchbase
At some point it finds the word "Investors" and copies the information below this cell and put all together in just another cell.
I need to do it for the second occurrence of "Investors:" as well, but still bringing the information below the first occurrence of "investors:"
Can you help me?
the code with the problem is in blue.
Could you help me please?
Sub Macro1()
Dim site As String
Dim tag As String
Dim i As Integer
Dim s As Integer
Dim nrows As Integer
Dim LAstrow As Long
        Dim r As Excel.Range
      Dim d As Excel.Range
nrows = Sheets("Sheet1").Range("B1").Value
For s = nrows To Sheets("Sheet1").Cells(nrows, 5).End(xlDown).Row
site = Sheets("Sheet1").Cells(s, 5).Value
Sheets("Sheet2").Activate
    With ActiveSheet.QueryTables.Add(Connection:= _
        "URL;http://www.crunchbase.com/organization/" & site, Destination:=Range( _
        "$A$1"))
        .Name = "mattermark"
        .FieldNames = True
        .RowNumbers = False
        .FillAdjacentFormulas = False
        .PreserveFormatting = True
        .RefreshOnFileOpen = False
        .BackgroundQuery = True
        .RefreshStyle = xlInsertDeleteCells
        .SavePassword = False
        .SaveData = True
        .AdjustColumnWidth = True
        .RefreshPeriod = 0
        .WebSelectionType = xlEntirePage
        .WebFormatting = xlWebFormattingNone
        .WebPreFormattedTextToColumns = True
        .WebConsecutiveDelimitersAsOne = True
        .WebSingleBlockTextImport = False
        .WebDisableDateRecognition = False
        .WebDisableRedirections = False
        .Refresh BackgroundQuery:=False
    For i = 7 To 27
    tag = Sheets("Sheet1").Cells(4, i).Value
    Range("A1").Select
If tag = "Investors:" Then
Set r = Sheets("Sheet2").Range("A:A").Find(What:="Investors:", LookAt:=xlWhole, MatchCase:=False)
Cells.FindNext(After:=ActiveCell).Activate
If Not r Is Nothing Then
    Sheets("Sheet1").Cells(s, i).Value = Join(Application.Transpose(Range(r.Offset(1).Address, r.End(xlDown).Address).Value), ", ")
ElseIf tag = "investors2:" Then
Set d = Sheets("Sheet2").Range("A:A").FindNext(What:="Investors:", LookAt:=xlWhole, MatchCase:=False)
If Not d Is Nothing Then
    Sheets("Sheet1").Cells(s, i).Value = Join(Application.Transpose(Range(d.Offset(1).Address, d.End(xlDown).Address).Value), ", ")
ElseIf tag <> "Funding Rounds" Then
Cells.Find(What:=tag, After:=ActiveCell, LookIn:=xlFormulas, _
        LookAt:=xlPart, SearchOrder:=xlByRows, SearchDirection:=xlNext, _
        MatchCase:=False, SearchFormat:=False).Activate
    Selection.Offset(1, 0).Copy
    Sheets("Sheet1").Activate
    Cells(s, i).Select
    ActiveSheet.Paste
Cells.Find(What:="Funding Rounds", After:=ActiveCell, LookIn:=xlFormulas _
        , LookAt:=xlPart, SearchOrder:=xlByRows, SearchDirection:=xlNext, _
    Selection.Offset(3, 0).Copy
    Cells(s, i).Select
    ActiveSheet.Paste
    Cells.Select
    Selection.Clear
    ActiveWorkbook.Save
    Next s
attach a workbook with a source worksheet with at least 2 investors
and a desired result worksheet …
