Facing problem with index and Match function
i want to display the column header based on the given value when i am trying to do it with index ma
  • Total voters
    1
  • Poll closed .
Padam
i want to display the column header based on the given value when i am trying to do it with index match combination then its working fine but i am facing problem because my data is having duplicate values then by using match function it returns only the column name of left most first instance where as in next row i want it to return the column header of second instance. i am trying to do it with match and index. Do u have any alternate solution for this problem. For reference i am uploading file and the formula i am using .
Any help in this regard would be greatly appreciable...
Go through this link for an introduction :
http://chandoo.org/wp/2011/11/18/formula-forensics-003/
Dear Naryan,
As per your guidance i have applied that formula in my sheet, where as now the data resides in two sheets then the earlier sample that is data which i want to look for is in summary sheet and from there i want data to be displayed in sheet 1 but i am getting the wrong result, please check in attached sample i have highlighted the issues in red color. Please guide me further, your help in this regard will be highly appreciable...
See your file now ; the construct used is the correct one ; earlier I had not used this because the starting column was column A , which is numerically 1.
If your starting column is different , then you need to use this construct.
COLUMN('Summary '!$C$10:$AG$10) - MIN(COLUMN('Summary '!$C$10:$AG$10)) + 1
If your starting column had been A , then you could have used :
COLUMN('Summary '!$A$10:$AG$10)
without the additional part highlighted in the first construct.
