Excel VBA: Using Index/Match down a column
KC E
Yes, using Excel 2013, this is a continuation of a thread I posted earlier to try to speed up code I'm using on 2 sheets of data: https://chandoo.org/forum/threads/e...o-match-criteria-btw-wkbks.36033/#post-216132.
I have since moved the data to 2 worksheets within the same workbook (attached) to help speed things up b/c the data on the Billing wksht can be up to 300,000 rows--the Address List is the 1st wksht, and the Billing sheet is the 2nd wksht.
1) I'm using the 'Helper Address' column H, starting with cell H2, in the Address wksht as the lookup value to lookup values 2) in the 'Helper Address' column E (the lookup range), starting in E2, in the Billing wksht.
Where the answers will go:
The code will match the addresses btw. the Billing wkbk and Address wkbk and return that address (column E) from the Billing wkbk to the 'Address' column of the Address wkbk in column D.
Narayan stated in the thread I created in the link above that I could use Index/Match instead of looping through cells.
I've adapted code below to do that and added used With/End With, etc. to speed things up, but when the Index/Match puts the formula down column D of the Address List it just says #Name? down the cells. I have at least 2 addresses that should match between the wkshts.
None of the variables are capitalized in the Index/Match part of the code, though I don't get any errors when I run the code.
Can anyone help with what I am doing wrong?
Thank you.
Sub Test()
    Dim MatchTable, IndexTable As Range
    Dim LRow, ALrow, MatchAnsw As Long 'ALrow is address list last row
    Dim ToFindMatch As Variant
    With ActiveWorkbook
        With .Sheets(2) 'billing
            LRow = .Cells(Rows.Count, 5).End(xlUp).Row
            Set MatchTable = .Range("$e$2:$E" & LRow)
            Set IndexTable = .Range("$E$2:$E" & LRow)
        With .Sheets(1) 'address list
            ALrow = .Cells(Rows.Count, 8).End(xlUp).Row
            ToFindMatch = .Range("$H2").Value
        With .Sheets(1).Range("D2:D" & ALrow) 'address list
            .Formula = "=index(indextable, match(tofindmatch,matchtable,0))"
source: https://www.mrexcel.com/forum/excel-questions/728725-vba-formula-index-match-dynamic-range.html
Try this modification:
Sub Test()
  Dim cell As Range
  With ActiveWorkbook
  For Each cell In .Sheets(1).Range("D2:D" & ALrow) 'address list
  cell.Formula = "=index(Sheet1!" & IndexTable.Address & ", Match(" & cell.Offset(0, 4).Address & ", Sheet1!" & MatchTable.Address & ",0))"
Sub Test()
  Dim cell As Range
  With ActiveWorkbook
Thank you for your reply. I tried running this code and a dialog box opened when I get to the 'cell.Formula = "=index', etc. named 'Update Values Sheet 1' and it stays stuck. If I press OK, it closes briefly and then pops back up.
I have to finally force shut down Excel. When I open the Address List back up, I get a few cells in column D with #N/A.
I also think looping will be an issue b/c I will have data that is sometimes 300,000 rows long. When I looped before, Excel froze.
Can you or someone else help? Thank you.
Sub Test()
  Dim cell As Range
  With ActiveWorkbook
It works now. I added
cell.Formula = "=index(Sheet1!" & IndexTable.Address (True,True) & ", Match(" & cell.Offset(0, 4).Address(False, True) & ", Sheet1!" & MatchTable.Address(True, True) & ",0))"
This makes the formula like =Index($E$2:$E$2,Match($H2,$E$2:$E$2,0)). There might have been some formatting issue where cells were a certain format or something, but now there is a match.
I tested against a Billing sheet with 73,000 rows and it pauses a little while but it is much faster than before. God bless you.
