Excel technical issue - Iterative Calculations slowing down Excel?
3G
Hi there-
I was practicing Chandoo's circular reference/in-cell chart function lesson whereby you change the iterative calculations & whatnot.
Ever since doing that, my Excel has been significantly slower, and, I am now getting this message in the lower right hand corner of Excel showing my processors in use and the %.
What are the defaults to set it BACK? Not sure if that's causing the problems,but it's been much slower since then.
Thanks!
3G
Dunno if that's THE reason, but to disallow iterative calculations:
1) Go to File > Options (in 2010). I think 2007 it is Excel Options from the Windows button.
2) In the "Formulas" tab, uncheck the box that says "Enable Iterative Calculations".
Hope that's all it is....
you can try max iterations to 100 and max change to 0.001. It depends on versions as well. Another eazy option may be disable iterative calculations by unchecking the option.
