Sub Mail_Range()
'Working in Excel 2000-2013
'For Tips see: http://www.rondebruin.nl/win/winmail/Outlook/tips.htm
Dim Source As Range
Dim OutBody As String
Dim OutApp As Object
Dim OutMail As Object
Set Source = Nothing
Set Source = Selection
On Error GoTo 0
If Source Is Nothing Then
MsgBox "The source is not a range or the sheet is protected, please correct and try again.", vbOKOnly
Exit Sub
With Application
.ScreenUpdating = False
.EnableEvents = False
With OutMail
.to = "ron@debruin.nl"
.CC = ""
.BCC = ""
.Subject = "This is the Subject line"
.HTMLBody = RangetoHTML(Source)
'.Send 'or use .Display
.display 'Current set just to display. Comment out whichever line you want
On Error GoTo 0
Set OutMail = Nothing
Set OutApp = Nothing
With Application
.ScreenUpdating = True
.EnableEvents = True
Function RangetoHTML(rng As Range)
' Changed by Ron de Bruin 28-Oct-2006
' Working in Office 2000-2013
Dim fso As Object
Dim ts As Object
Dim TempFile As String
Dim i As Long
Dim c As Range
Dim TempWB As Workbook
TempFile = Environ$("temp") & "\" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
Set TempWB = Workbooks.Add(1)
With TempWB.Sheets(1)
'Build the message
i = 0
For Each c In rng
.Cells(1 + (4 * i), 1) = "Name"
.Cells(1 + (4 * i), 2) = c.Value
.Cells(2 + (4 * i), 1) = "Gender"
.Cells(2 + (4 * i), 2) = c.Cells(1, 2).Value
.Cells(3 + (4 * i), 1) = "Age"
.Cells(3 + (4 * i), 2) = c.Cells(1, 4).Value
.Cells(4 + (4 * i), 1) = "Fruit"
.Cells(4 + (4 * i), 2) = c.Cells(1, 7).Value
i = i + 1
Next c
'Publish the sheet to a htm file
With TempWB.PublishObjects.Add( _
SourceType:=xlSourceRange, _
Filename:=TempFile, _
Sheet:=TempWB.Sheets(1).Name, _
Source:=TempWB.Sheets(1).UsedRange.Address, _
HtmlType:=xlHtmlStatic)
.Publish (True)
'Read all data from the htm file into RangetoHTML
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
RangetoHTML = ts.readall
ts.Close
RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
"align=left x:publishsource=")
'Close TempWB
TempWB.Close savechanges:=False
'Delete the htm file we used in this function
Kill TempFile
Set ts = Nothing
Set fso = Nothing
Set TempWB = Nothing
End Function
