Max Alejandro Molina Member Apr 3, 2015 #1 Hi Excel Ninjas, I am trying to format the numbers as following: Less than 0 = RED Equal to 0 = Light Red From 1 to 30 = Orange From 31 to 60 = Yellow Bigger than 61 = Green Can anybody help me out? Attachments Conditional Formatting Help.xlsx Conditional Formatting Help.xlsx 24.1 KB · Views: 2
N NARAYANK991 Excel Ninja Apr 3, 2015 #2 Hi , See the file. Narayan Attachments Conditional Formatting Help.xlsx Conditional Formatting Help.xlsx 27.8 KB · Views: 2
Khalid NGO Excel Ninja Apr 3, 2015 #3 Hi Max, Alternatively you can use excel's built-en options: e.g. for Range: 1 to 30 Set format to your choice. Do this again with different format for 31 to 60 Set different format. and similarly there are more options for Equal to... and Greater than... Less than... Regards,
sudipto3003 Member Apr 3, 2015 #4 hi Khalid, Narayan have used the same option you have mentioned....
Khalid NGO Excel Ninja Apr 3, 2015 #5 sudipto3003 said: hi Khalid, Narayan have used the same option you have mentioned.... Click to expand... Hi, No, if you go through Manage CF Rules you will see that Narayan Sir used formulas like: =AND($E1>30,$E1<=60) =AND($E1>0,$E1<=30) =$E1=0 And I've used built-in options for the same... Regards,
Max Alejandro Molina Member Apr 6, 2015 #6 Thank you all for the help! I have noticed that when I sort the numbers from bigger to lower or backwards, this conditional formating does not work properly do you guys have any comment to this issue?
N NARAYANK991 Excel Ninja Apr 6, 2015 #7 Hi , I tried it and there is no problem. Everything is colored as it was before , and according to the rules. Narayan
