Combining =INDEX with =OFFSET
Wulluby
I have a chart that is working with a scroll bar, in cell W15 I have the following formula:
=INDEX($Q$15:$Q$78,$Z$38)
I am now trying to add the ability to switch from viewing one set of data with another using:
=OFFSET(W15,0,$W$38)
If I am right in how I am interpreting this I need to combine those in the same cell, the closest I’ve got to a result trying to combine these is:
=OFFSET(INDEX($Q$15:$Q$78,$Z$38),W15,0,$W$38)
I take it from my lack of success that this is not the correct way to combine these 2 formulas, would anyone be able to point me in the right direction for this?
To give it some context, I have used the simple gantt chart example as an exercise from http://chandoo.org/wp/2008/05/20/gantt-in-60-seconds-churn-out-an-excel-project-plan-in-no-time/
I have increased the amount of activities to around 50 so that I can learn the basics of setting up a scroll bar which I have got my head round and using the =INDEX($Q$15:$Q$78,$Z$38) to do. At the moment this chart is now displaying from columns titled Planned Start and Planned Duration, I am trying to switch what is being displayed from Planned to Actual. I can see the method behind it and can make it work outside my table with a simple =OFFSET(W15,0,$W$38) but I am not having much luck at combining everything into a chart that will allow me to view either Planned or Actual with the ability to scroll.
I appreciate any pointers anyone might be able to give me on this.
I think you just have one extra argument in your formula.
=OFFSET(INDEX($Q$15:$Q$78,$Z$38),0,$W$38)
The INDEX function is being used to return the reference point for the OFFSET, which then looks x columns to the right, where x = value in W38.
That works perfect.
It makes a lot of sense too, thanks for that.
I feel like I've learned 1 or 2 big fancy words in a different language but should be mastering the smaller building blocks of sentences like this kind of stuff.
Thanks for your reply Luke.
