Greetings,
I have a Pivot table with values in cells A5 - B10000 (headers in Row 4). In the Pivot, Column A has the name of a Company (e.g. XYZ Company) and Column B has a count of that companies occurrences from a larger set of data (e.g. 3).
I'm attempting to extract the top 30 values - i.e. the top 30 Company counts - from the Pivot...and there will be duplicates. For example, Company XYZ and Company ABC may both show up 3 times.
In the same tab as the Pivot, I've setup the below formula in cells F5 - F34. In E5 - E34 I've listed out the numbers 1 through 30. The formula seems to work for my first value (i.e. 1) but isn't accurate after that one. Any thoughts on what I'm doing wrong? Is there a better way to do this? (NOTE: any formula I use should be based on the Pivot table setup, not the raw data)
{=IFERROR(INDEX($A$5:$B$10000,SMALL(IF(ISNUMBER(SEARCH(LARGE($B$5:$B$10000,E5),$B$5:$B$10000)),ROW($B$5:$B$10000)-ROW($B$4)),ROW(1:1)),1),"")}
Thanks in advance!
Thanks in advance!
